obd2 test
shoman07
Waterford,MI
Ok well i tested my car after the check engine light has been on. Ok well the first sensor said po 113 IAT sensor 1 circuit high input/ The secound one said pl518 vechicle manufactured controlled speed, idle control, and auxilariary input(yes that is one) The third one said po401 EGR flow Insufficient. That is it for today. Thanks For the help you can give me
midnightauto
THE CHOP SHOP
Michigan
PO113 is probably that cold air intake you just put on. and left the sensor in the old air box
my guess is your driving habits attribute to the other two codes so stop racing gen 2's
shoman07
Waterford,MI
Well it wasn't much of a race from a deep stop but from 40 we where close. I forgot about the temp sensor that i took out.
JVANBUREN
holly, mi
Just dont worry about it and take it easy and maybe ill fix it for you. Your list of things to do is just getting longer and longer.
Mr Anonymous
Tire Wall
Stuck IMRC (and probably a broken acutator) and clogged EGR passage in the surge tank, and yeah a missing IAT sensor will throw a code.
