O/T: 3.8L V6 no spark problem - troubleshooting ideas?
revhardSHO
Seattle, WA
Sorry about the off topic post, im stumped about this spark issue. Just finished up doing the HG's on this 93 taurus wagon (i dont need to tell you - it has the doomed 3.8L), everything went together quite well. Ive triple checked every electrical connection and wiring harness. Timing is set. The problem; no spark from the coil. Ground is good. Ran the codes and got nothing ignition/spark related. The engine cranks over but doesn not fire. Checked 10A coil fuse, good. I dont know what else to check. Anything simple im overlooking here? Is there another fuse somewhere in this system? Helms manual suggested I "Clear Continuous Memory", but there is no procedure. Anyone know how to do this? It has the ECC-IV computer, distributer ignition NOT like the our SHOs distributerless ignition system. It uses a remote-mounted ICM, which i have no clue where. I would like to get this thing started and out of the garage ASAP. Any help would be greatly appreciated. Thanks alot
Silas
Slo-Sho
It wasn't me!
Crossroads, CNY
If you have a DMM, now would be a good time to dust it off. I would check connection itself at the coil for power, broken wires can often be masked by the insulation. You can also try energizing the coil itself.
tinkerkathleen
