94shodriver
My '94 has been sitting in my dad's shop for the past year only being driven out to make room for working on other vehicles. The last time it was constantly driven was the summer to 2018. At the end of the summer, I had a partial clutch failure at the track, so in the shop it went. At the time there were no ignition issues, at some point while in storage or just prior to, the water pump began to leak. Later on, it wouldn't start. There was no spark but the RPMs were displayed on the tach while cranking, 600-700 rpms. After a quick swap of the camshaft position sensor, just to rule it out quickly, my dad did a front 60k on it to replace the failed water pump, instal a new timing belt and tensioner, and replace the crankshaft position sensor with one that came from a different spare engine that was working when it was removed. After putting it all back together, there is still no spark. I'll get the codes, but at this time, all I can think of for potential culprits, are the coil pack and DIS module. Any other thoughts?
The engine and ignition is mostly stock other than an under drive pulley, aftermarket y-pipe, and a 3.2 swap. The 3.2 swap was done about 45k ago with new top, front and bottom 60k maintenance. The plugs were replaced about 5k ago and the wires were new with the swap. The fuel pump comes on when the ignition is cycled on.
