O/D On/Off not working 93ATX
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
I did a search and came up empty.
I just noticed the other day that my overdrive button is un responsive. it just worked last week. OD is on (Which is good)
Is this a common issue? How do I go about fixing it?
n8rsk8r
Hey Where's my post?
Olathe, Kansas
mine failed. you can pop it out of the side, the part is not much from ford. Good luck!
ml98188
Seattle
Had the same problem. Could be a number of things. Bad switch, loose/bad OD solenoid, bad relay somewhere, bad ground, bad 'puter. Here's the history on mine:
First replaced switch(First at the Dealer- they screwed it up, took it to my mechanic-fixed it right)
Replaced tranny and all tranny electrics (needed it anyway and it was planned).
Still had OD that would work sometimes - kick in or out a the most inopertune moments (like going 80 on the freeway and BAM- downshift). Sometimes it would flash in and out just sitting at a stoplight. Turn it on - it goes off and visa versa.
A full reset of the ECC would cure it for a while but it would slowly start failing again. Noticed that it would be OK in the morning when I first started out but would start up again (failing intermittently) after a bit of running here and there. Acted like it was heat related somewhere.
Reasoned that it may be a weak heat sink or something in the 'puter or a bad relay or ground. I always go the easy route first and I really didn't want to start poking wires so I found an ECC with no known issues and replaced the computer. (Thanks Rick) Haven't had a problem since.
In retrospect it may not have been the ECC and just the action of R&Ring it reset the connections. Kinda like reseating the boards on a screwy computer. My money says it was the 'puter,though. If replacing the switch doesn't work - start there.
TopGunnYFZ
Livonia, MI
On my 94 i had the samething happen, I would hit the O/D and nothing would happen. I did a search on here and found out that a lot of times the wires get pinched and they get cut. Take your center console out and see if your wires are still both together, and if they are proceed to take your shift **** off carefully so you dont rip the wires right off the switch like i did after i had fixed the wires LOL
