now my enginge won't start right!
Rogue10186
The Cajun
Louisiana
I just got done putting my intake manifold back on after replacing my plugs, plug wires, and valve cover gaskets on my 93 ATX. I am positive I connected everything right because I had my mom and my Grandpa (a retired marine mechanic) to check to make sure I plugged everything up properly. After my grandpa went home I tried to start the engine, and it cranked and fired up, but then died about 2 seconds after starting. I tried it two more times and found that if I held the gas in a litle it would stay on, but if i let go of the gas to idle the engine, it would just die. At the time i didnt have the air filter installed, but i had the filter cover and everything else hooked up. My grandpa thinks that something may be wrong with the idle program in the car's computer but he's not sure b/c he wasnt there when i started it. If this does sound like a computer problem, what cna be done to fix it, and if not, what else could be done?
SilSho95
Michigan
I just had the same problem 2 days ago, I checked my intake to head bolts and they were not torqued enough so I torqued them down and it runs fine now. check the thread a little farther down titled need help.
wood_e
The dude
Ames, IA
you sure you have the IAC valve hooked up properly? Mine did the same thing and i forgot to plug the damn thing in
what wood_e said, fisrt.
You also have to make sure thet the MAF is connected and that the intake air is actually being pulled through it. If the intake tube were not connected, you would have your symptoms.
Rogue10186
The Cajun
Louisiana
got it going strong now!
I removed the IAB and cleaned it out, man was that bad lookin! After I put it back on, my Grandpa and I adjusted the throtle screw a litle bit, and it runs just fine now! :****:
Thanks for the help! :thumb:
autobahnsho
SHO Victim
NY for now, WY for real
Rogue10186 said:
the one that adjusts where the throtle flap is when you're not on the gas pedal?
Yeah, you're not supposed to touch it.
You CAN move the throttle sensor around alittle, then tighten the screws. It's the black piece with wires on the front of the tob (towards front of the car, anyways).
autobahnsho
SHO Victim
Well, it doesn't say 'right on' the screw, but it says on that annoying piece of plastic with all that garbage information that the idle is not adjustable. :cool:
