Rogue10186
The Cajun
I just got done putting my intake manifold back on after replacing my plugs, plug wires, and valve cover gaskets on my 93 ATX. I am positive I connected everything right because I had my mom and my Grandpa (a retired marine mechanic) to check to make sure I plugged everything up properly. After my grandpa went home I tried to start the engine, and it cranked and fired up, but then died about 2 seconds after starting. I tried it two more times and found that if I held the gas in a litle it would stay on, but if i let go of the gas to idle the engine, it would just die. At the time i didnt have the air filter installed, but i had the filter cover and everything else hooked up. My grandpa thinks that something may be wrong with the idle program in the car's computer but he's not sure b/c he wasnt there when i started it. If this does sound like a computer problem, what cna be done to fix it, and if not, what else could be done?
