I have a similar problem, you see when my tach drops to zero, the engine still idles and drives fine, no bucking, power loss, hesitation or dieing.
Ask GuruComputers about that one, it sat idleing in his driveway while we talked shop for nearly thirty minutes and never died, I even drove it home, and on the way home the tach picked back up and no problems after that.
When I did shut it off after getting to his house (tach dropped to zero on the way) it was a hard start, but still fired up and ran fine...
MY question is, there are no codes stores, none come up for KEOE or KEOR tests other than when I plugged in a tester and ran the KOER test (while engine running) the only thing the code reader told me was that it couldn't control the idle speed during the test, but I watched the tach go up and down during the balance test, and all that junk.....
the Crank Sensor is still factory as far as I am aware (vehicle has 206k+ on her...miles that is...) of and also I thin the cam sensor is factory as well..
Should I just replace both? I did pull the DIS module ( the thing on the side of the intake) from a wrecked-but-otherwise-perfect low mileage red '93 ATX (Mine is a '95)
Any ideas?
