No Stop
AREA 91
PA SHO SHOP
Area 91
I can't get my 90 SHO to shut off with the key! Starts and runs great, just won't shut off! I have tried several things so far, including:
CCRM
computer
alternator
starter solenoid
ignition switch
Still a no go! Any suguestions??? :confused:
Foxwulfe
Somewhere
I know you know what you are doing, but..
Did you replace the ignition switch and the lock cylinder?
Could there be a chaiffed wire coming from the igniton switch to the ECM?
A stuck relay or bad solid state switch?
Did you mean IRCM, instead of CCRM? (I can not recall if that is the same thing)
