No Start
I'll sho u
saint john,nb,canada
check all the connections by the battery.verrey close to it is a ground connection for the computer.It is a black wire with a round black connector in the wire.It is not unheard of for it to be corroded or become unpluged while working under the hood.
vance580
monroe, mi
Another Idea
Well I thinking since I'm getting the three things: Spark Fuel and Air. I'm wondering if my injectors are clogged from it sitting cause I'm not sure if the fuel is going into the combustion chamber. Is there a way to clean injector without removing them or starting since it dont start or do you think I could push start it and just let it run a while till I get the bad gas out. Also ran codes now only getting a 111.
JMoff92
Rochester, NH
You are not going to be able to push start it. If you want to clean the injectors, you are going to have to remove them.
Maybe the spark isn't strong enough and the problem is your computer like somebody else mentioned.
vance580
monroe, mi
Yea I'm thinking its the computer thats the only thing thats left I havent replaced. I've replaced pretty much everything that would cause it not to start. I'm think my computer must of fried somehow and that might be why my ignition switch has the burn mark in it. Well time to start looking for a computer lets see how much thats gonna cost me.
