No start on first attempt...
mylaw
The Sho Time
Ottawa
When I go to start my car it does not catch on the first crank... I have to turn the key of then try to start it again ... Any ideas
I have replaced plugs wires gas filter o2 sensor and MAF sensor..
Just would like to get it fixed before the winter comes....
plethaus
Kittyland Love Center
What do you mean it won't "catch".. do you mean it cranks and cranks but won't actually start or do you mean the starter isn't cranking the engine right? If it's the latter you might need a new flywheel or have it resurfaced
mylaw
The Sho Time
Ottawa
It won't catch on the first try all the time but sometimes it does !
SW SHO
Boss Man
Santa Fe, NM
If by "no catch" you mean the car isn't turning over, but the starter sounds like it is engaged, then I would look at the starer first, then the flywheel. If the starter sounds (whining) like it's working but not "catching" the flywheel then you've got a bad starter. (I've replaced 3 in 8 years and that's exactly how it begins)
If by "no catch" you mean the car is turning over but not starting then you could have several issues and more info would be needed to assist.
SuperHO
Mental Patient
St. Joe, MI
I have something of the same problem with mine......I was told by someone who happens to know their shit that the problem's in my fuel pickup. something about the return valve on the pickup unit.
mylaw
The Sho Time
Ottawa
The car turns over normally but does not start
I then turn it over again and it will start... I also have been noticing alittle hesitation at steady speeds ..
mylaw
The Sho Time
Ottawa
is that hard to replace !
If the rpm moves what could it be.
SuperHO
Mental Patient
St. Joe, MI
Umm...what he's describing isn't the "cid".....what you're describing is the CKP...crankshaft position sensor....and his symptoms aren't suggesting anything related to that.
For some reason, I'd theorize that your not holding fuel pressure after turning off the vehicle. As stated before, mine does the same damn thing. I've replaced everything fuel related under the hood except for the injectors, and nothing's worked thus far. After talking to Doug Lewis at Ford Performance Specialists, I've found that my pick-up is to blame. The return line has a lil valve in it, and when pressure's not on it, the valve stays closed to keep pressure in the system for re-starts. That valve goes bad, and pressure drops in the fuel rail, thus having to try multiple times to start it. There's 2 fixes.
1: Buy a new pickup and replace it.
2: don't be so impatient and let the fuel pump prime for a second or two before attempting to start the car.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
yea id go there first.
Theres a way to get it out quickly , with cutting a hole under the rear seat...now where did i saw that....anyone got a link?
jelloslug
Digital
Greenville, SC
If you CID goes bad the engine does not know which bank of plugs to fire when you try to start it. You will have a 1 in 3 chance of it starting. If it is bad your tach will not work either. I know this from personal experience.
Bizzy
Do you have fuel pressure and spark? What about codes from the computer? You need to run those and let us know what they are. Many times your computer will tell you everything that's wrong and is the first place to start along with verifying fuel pressure and spark. Without that basic information the only thing we can offer is guesses and guesses can sometimes cost tons of money.
SW SHO
Boss Man
Santa Fe, NM
"WORD!" :thumb:
