91 Plus
Well-Known Member
Ok I just picked up a 95 atx..
I dont know much info on the car at all.
The car is cranking over but will not start.
The car has fuel and spark.
The tach goes up to about 500 while cranking. We also put a little starting fluid in here to see what it would do. Didnt even chug or try to start at all..
Motor seems to be turning over fine. Any sugestions..?
Possible timing? Thanks
Also there are new plugs in the car. We pulled the front 3 plugs out and they were all firing fine. We sprayed starting fluid in each cylinder. We tried to crank it back over with no luck of anything. No back fire, no chug, nothing just keeps cranking..
