No start after replacing water pump
gbizzle27
Bradford, Pa
Finished up the water pump job and my car wont start. I replaced the water pump, Camshaft position senser, and crankshaft position senser. I put the timing back correctly, bolted down the crossover tube. It seems to me i did everything correctly. Any suggestions on what to do next?
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
TYSHO said:
Did you gap the CPS correctly?
i am on the same page and same question?? and the gap size is 0.33 so if you havent done that, man sorry but you have to redo some stuff in there.. good luck
endri:thumb:
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Assuming that you removed the crossover tube, make sure it's probably grounded to the intake FIRST! If not, it'll crank all day. And as stated above, if you didn't gap the CPS properly, that may as well be the culprit. Good luck!
TYSHO
Earth
Make sure you plugged the CPS in, also. Just rethink what you did and didn't do, it's probably something simple that you forgot about.
gbizzle27
Bradford, Pa
oops, timing was off. there was another mark on the crank gear thing and i used that. My bad, but it's almost back together.
TYSHO
Earth
Glad you found the problem. I would also check that CPS gap if you didn't already. :thumb:
gbizzle27
Bradford, Pa
yah i gapped that to .03. While it was apart i painted everything up so it will look good, along with run good.
TYSHO
Earth
Get some pictures up when you're finished. :thumb:
Endri_SHO
SE 300 , S 500
yeah get some pictures, ia m about to do my 60k full service in my 93 beast so i wanna have some ideas of colors what to chose for powdercoating the engine bay around...:thumb:
