this is a 94 135k sho.ween i brought it home from the dude bought the car form everything seem fine.It ran like its suppost to.then the fan burn up it pretty bad.burned the wireing harness also where from the fan runs in to the little connecter to the main wiring was melted gone.so i cut the bad wires,taped em up run the new fan to the battery.and then the car sit 4 a mouth or so.i go to start it and it turns over but dont catch.ran the battery down 2 times before i finally get it to catch.then it ran fine,got it home to fix the oil leak and timeing belt it was cut.
fix it connected every thing back
and it'll crank but on start.just like last time.so i say the crank sensors the trouble but,i tuck out a plug on the wire friend turned her over and no spark.got a wire tester and checked to see if the coil,dis,and power was sent to it if that help.self test code 116,114 but thos haven't any to do with fireing.the big relay box is old,coils old and the dis is old.im sorry for this email the thread was looked at alot i thought nobody wound respond.so please help me.if i left out any info u need let me know
