I just replaced my fuel pump with sho source 160lph fuel pump and still having same issue, no fuel pressure and can't here pump prime. I'd been having low fuel pressure and thought the pump just died but when i changed the fuel pump found a pin size hole in the plastic fuel lines.
So far have change out ccrm and checked 20 amp fuel fuse and both are good..... sooo where should i check next?:thankyou:
