No power to fuel pump?
shoftw
I just replaced my fuel pump with sho source 160lph fuel pump and still having same issue, no fuel pressure and can't here pump prime. I'd been having low fuel pressure and thought the pump just died but when i changed the fuel pump found a pin size hole in the plastic fuel lines.
So far have change out ccrm and checked 20 amp fuel fuse and both are good..... sooo where should i check next?:thankyou:
shoftw
WTF!!!! I just jumped 11 and 5 on the ccrm connectors and my fuel pump worked but that would mean the ccrm is bad right? That does not make since because my ccrm worked fine in my other taurus that i switch it with????..........
shoftw
Ok after checking out some things i found out i have no spark from the coils and im pretty sure the injectors are not firing because i still have 22 psi from when i jumped 11& 5 on the ccrm.
sooo what would make car not power the fuel pump, not cycle the injectors,and not fire the coils??? I think i know where this is heading and i dont like it.
shoftw
Thats what im thinking........ I hope not because that means im gonna have to have it programed at the stealership.
jmpSHO2nd
Massachusetts
I thought I read some where that you can program a key without going to a dealer. Anyways if you get a PCM look in the car you get the PCM for and try and find the key or ask the JY if they have the key some place.
I'm going to try and find the thread I read about PATS. Also if you can't program the key yourself I know some shops can do it for you so you wouldn't have to go to the dealer.
