it is not going to be out of time - that is computer controlled.
the only way to screw up the timing is to remove the little stamped steel shutter piece that fits on under the cam sensor and put it back on half a turn off.
the crank sensor is tricky to get installed properly - the magnet will try to clamp itself to the shutter wheel on the crank, which will result in too large of top gap, no bottom gap, and a destroyed crank sensor in a very short time. If you are not sure you gapped it properly, you need to check that.
However, since you say you have spark, the crank sensor is still working.
Now, just because you hear the fuel pump run for a second when you turn on the key does not mean you have fuel pressure. The fuel pump running does not have to equal fuel pressure. So you need to confirm that you have fuel pressure.
After you know you have fuel pressure, you need to confirm you actually have fuel in the cylinders. If you have been cranking the car without it starting, you should have plugs that are wet from fuel. In fact, you might need to remove them and clean them before it will want to start.
Check those things and let us know what you find.
