no fuel to the rail
mattsho1993
SHO owner
albion, new york
i got the trans and motor in today all bolted up. the thing is im not getting any fuel to the rail... i hear the pump but nothing.... and also i found a plug unplugged cant find where it goes its a black plug with a blue inside and one prong its round with a sort of corner on it? also its by the computer and its got a long harness to the main.... i had somedude look on his '90 and he didnt see anything like it....:nuts:
SinisterSHO
Rust free
630, IL
if the pump is working and you're not getting fuel to the rail, are you sure the fuel lines are attached to the rail?
firebat45
Edmonton
If they weren't fuel would be pouring out of them, I think he'd notice.
Silly question, but are you sure you got fuel in the tank? If the pump is working, then fuel either has to be not getting to it, or going somewhere down the lines.
mattsho1993
SHO owner
albion, new york
yeah deff. connected the lines lmao ;) but which port do i test it. your talking bout the check engine box right which one do i test/jump? Its been sitting for a while so maybe some of the gas evaporated ill have to check but i dont think thats it!!!!???? what else would cause it...????
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I can't remember which pin it is off hand... but what I do know is that it needs grounded out... :)
Grab a peice of wire.. wrap it around the battery ground, then stick it in the "EEC Test" plug.... and IIRC, if you hold it with the wide side down, it should be the pin on the bottom right... should be one of two on top.
When you find it, you should hear the CCRM click, and she should run. I do this when say I want to drop the fuel tank... pull the filter off, and catch my gas by the back wheel there.. :)
Also check and see if maybe one of them isnt kinked... its kinda funny hose, and I can see how it might kink under the right conditons..
Westerly, RI
The plug you're talking about is the PCM ground to the battery. Off your negative battery cable, there should be a smaller wire with the mating plug on the end of it. Your car will not run without this connected.
mattsho1993
SHO owner
albion, new york
yeah it just sits there and turns and when it seems its gonna start it sounds like a grind noise like the starter stopped the rpm tack is all over the place too
mattsho1993
SHO owner
albion, new york
idk this $hit is ******* me off... got fue,l got spark, all grounds attatched, all plugs plugged, fresh battery just had it charged and tested at the zone.... the only noticable thing i see is the donors cam sensor was spliced in but all is sturdy none loose.... help guys
Westerly, RI
It's gotta be timing then. From what I read, you reset the timing belt using the dot on the timing belt sprocket, and the line on the block? If so, are you sure you were at TDC for #1?
mattsho1993
SHO owner
albion, new york
i set the cams at tdc but i cant get the crank pulley off so i backed the tensioner off. I then pulled the belt off the cams, set the first dash on the pulley to the 0* mark..... i also tried the second mark idk.....
