No Fan Come On-Hot N errr
DigDeez
Chicago
I must admit, I haven't done a search on this topic yet.:type:
But, I don't think my fan is working on my SHO. I don't hear it come on during my EEC testing as I should, just like the fuel pump relay box and the fuel pump. Plus, I noticed the other day that my temp guage went all the way up to the H. :oogle: :oogle:
All of my fuses checked out fine! I need to check the connecting wires, but if anyone have any ideas as to where to start, let me know! It's helping that it's still cold here in Chicago! But, I need to get this resolved asap!
Thanks!
frosho
WOLFMAN
Tyngsboro, MA
X2
i'm pretty sure mine don't work either... i was going to post about it when i get back to my car in MA for the summer and do some fiddling around but this way i'll know where to start. please post some thoughts!
DigDeez
Chicago
Anything wires and connector related that I can check for before installing a new fan? What should one do for a replacement, by the way? Price? WTB? Easy r&r? Thanks!
DigDeez
Chicago
SHOtimer said:
Does your fan turn on when you turn on your AC?
I know that www.rockauto.com has the fan assembly available for the ATX...
Doug
I'll try that, and I'll try and see if I can goose the fan to come on thru the CCRM box. Although, thru play I'll find out which prongs control the fan, does anyone know exactly which ones do?
Tao
TBaySHO
Thunder Bay, Ontario
I would go under there and make sure they spin when you poke them with your hand, if they dont or they make an obnoxious clicky noise its time for a new fan motor, if you want to test them grab a battery and some 10 Gauge wire and hook the terminals to the +/COM for the fan.
If they look ok check the 50A fuse with a 12V lamp tester, if thats OK then I would check the pins on the CCRM (relay box under the Emissions Cover). I think PIN 3&4 for ATX and 1&2 for MTX, they should have 12V when the KOEO test runs to test the fans. If thats checking out ok then there is a short or open in the harness somewhere and you'll have to poke around for it.
DigDeez
Chicago
Good news! It was just a connector that had came unfastened! Thanks all, nonetheless!
