No brakes!!!!
Sammy~D
Wrench Whore
Anoka, Minnesota
OK so I have brakes at all i checked the vac line to the bolster thats good. Checked the fluid level good. I blead the brakes thats good, no leaks in the line nothing on the ground at all. New pads new rotors. What happens is i press on the brakes its tight for a second then drops to the floor so i blead the brakes again i thought she hardens up and nothing at all again fluid levels are good no bubbles in resivor. i have about had it with this car:madflame:. please help me i am thinking to complex for it so if you have any ideas what it could be that would be great. let me know what you think
Thank you alot :thankyou:
Sammy~D:
jmpSHO
Massachusetts
Did the MC ever go completely empty? If it did you will need to bench bleed it. When I did my brakes, I installed ss lines, new pads and rotors all around and I blead my brakes for a good 4 hours before I got a firm pedal again.
Sammy~D
Wrench Whore
Anoka, Minnesota
ok i will give her a shot cause it did go empty all the way i had to replace both rear lines they blew up so i guess its a trip to wal*mart to buy 80 gallons of brake fluid :woo-hoo: ill keep you updated
