No boost :(
Iamstaypuff
Kentucky
2015 non pp. Last sunday I installed the epp intake and noise maker delete. Not being use to the t clamps, a couple of them came loose. The silicone hose came off the front turbo, and the noisemaker delete silicone hose came off the throttle body. After install I took it on a test drive and could hear the turbo is too loud. Re-secured the hose and went for another test drive finding that I had no boost and no bov noise. Looked again and found the hose off the throttle body. Reconnected it ,and checked codes. Low boost turbo a. Clears code and drove again. Still only 3.5lbs of boost. IDK what I did. Been at a shop for a couple days but I don't know if the tech is even looked at it yet. Any help is greatly appreciated.
Nova
US
Sounds like you didn't tighten the clamps tight enough.
76FoMoCo
Nampa, ID
always take some carb clean on a rag and clean all connecting points to remove all oil.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
those clamps are fun. When you think you've tightened it enough, tighten it more.
like @76FoMoCo said, clean all the connections and then you'll be able to tell new leaks from old if you get blow by.
ridered74
Just don't tighten them too much or they will break. I broke two of them during install, one with a tiny hand ratchet.
skyshadow07
Oklahoma
ugga dugga, my and my buddies say that shit all the time! lol
You know I've been told for years that T clamps can break if over tightened but I think people are either buying cheap clamps or maybe binding them. I impact all my clamps and have NEVER (knock on wood) broken a T clamp.
I made a boost leak tester with plugs and tire valves. Unfortunately it's built for a FMIC application with 3" pipe at the TB and 2.5" at the Hiroshima hairdryers. I would make you one otherwise.
12KSHO
