new parts in the mail!!
187 SHO
west babylon,ny
im ready 2 tackle my struts,stru t mounts&lowering springs..any tips or tricks i should know of to make the job go fast without any mistakes?
SHOGUN88
1994 MTX
Langley, BC Canada
Just note how you take averything apart, keep your parts in order and double check everything you put back together. Good luck!
Cocoa,Florida
1.PB blaster
2.good impact and sockets,open end for the rear struts.
3.big f'in hammer
4.spring compressor
5.something to pop the ball joints out,I perfer to use the jack handle with some leverage.
RAYJAY
WHO ME ?
UNION DALE PA
1.PB blaster
3.big f'in hammer
4.spring compressor
what he said plus you may need some heat for the front bolts i have better luck on the front pinch bolts when a warm them a little it softens the thread lock on the bolts
Jeff
crazy_canadian
Rattle-Mobile
Quebec
Jeff
Yeah I broke 2 of them when I did my suspension because I didn't had a torch. I replaced all 4, they were about $8 each at the dealer.
RAYJAY
WHO ME ?
UNION DALE PA
very first one i did i broke also because no ever said about the thread lock on them
you can also get the bolts at the auto parts store
Jeff
lowc
aka vapah lock
Quincy, massachusettes
and if you deside to take apart the strut assembly DO NOT TAKE OFF THE CENTER BOLT untill you have it safely secured in a spring compresor
jayro
Auburn, In
1.PB blaster
3.big f'in hammer
4.spring compressor
x2 on the big f'in hammer, torch and pry bar. Its amazing how strong those "Rust Welds" can be.
VortecGT
Wisconsin
btw don't use an impact on the pinch bolts! Turn them out, then back in, then out a little more etc... spray everything with PB Blaster and let it sit overnight and repeat for a couple days.
shotime1994
AirHammerAndrew
New York
Hey I'm in lake grove and could lend a hand if you need. Just P.M me your number.
RAYJAY
WHO ME ?
UNION DALE PA
why do not use a impact gun ??? use one every time and i break less bolts with a impact than a wrench or a ratchet, the impact is just better to use on the pinch bolts you just have to feel the bolt coming out with the impact gun, i must have done dozen of them with a impact gun and only had to drill one out because of not heating it, and that one i broke off with a ratchet.....
jeff
VortecGT
Wisconsin
when I did my rears I used an impact and the bolt did start coming out but then snapped. Plus without it you can feel if its getting harder to turn. Just my thoughts.
