187 SHO
im ready 2 tackle my struts,stru t mounts&lowering springs..any tips or tricks i should know of to make the job go fast without any mistakes?
1.PB blaster
2.good impact and sockets,open end for the rear struts.
3.big f'in hammer
4.spring compressor
5.something to pop the ball joints out,I perfer to use the jack handle with some leverage.
what he said plus you may need some heat for the front bolts i have better luck on the front pinch bolts when a warm them a little it softens the thread lock on the bolts
Jeff
Yeah I broke 2 of them when I did my suspension because I didn't had a torch. I replaced all 4, they were about $8 each at the dealer.
1.PB blaster
3.big f'in hammer
4.spring compressor
btw don't use an impact on the pinch bolts! Turn them out, then back in, then out a little more etc... spray everything with PB Blaster and let it sit overnight and repeat for a couple days.
