tamadrumr88
Hi everyone, just bought non-running '90 SHO (no spark, fuel pressure is good though). High mileage (184k) clean AZ car, no accident history or body work/previous repairs.
Has Key On Engine Off code 15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure). Confirmed connector to PCM has 12.7v at pin 1, and ground to PCM is good. Separately tried swapping with another spare LOS ecu, swapped crank sensor, cam sensor, DIS, CCRM, etc and confirmed power at all the connectors, but no luck.
Cranks and sounds healthy, but not getting spark. Thoughts? Couldn't find any other threads with this code, or a fix. Can't wait to get it started, so I can move on to fixing the minor oil leaks. Spent all day yesterday swapping out known good parts individually but no luck!
