shoon
cliTaurus
The problem:
-Speakers POP when changing radio stations or changing modes (anything that makes the head unit beep it seems)
-When ignition is off and power antenna is retracting, speakers buzz
-Subwoofer does not work. No clue where to start.
This is how I wired my system:
ok so I hooked up a pioneer DEH-5900IB using only 2 connectors; the main power connector and the low level speaker inputs that go to the stock JBL amp.
I connected the low level inputs to 2 sets of RCA jacks and am using the front and rear pre-outs on my headunit.
Am I supposed to use any of the extra connectors left over or are those just for the cd player?
used all the wires within the red rectangles.
The 2 grounds in the first red rectangle were spliced together.
The logic mute / mute ctrl was spliced to the ignition wire
"Radio on" was connected to the power antenna control on the HU.
there was this one wire on a 2 pin connector that looked like it could be important but I wasn't sure what it was for. It's part of "redundant radio control" there was a CTRL wire wasn't sure how I was supposed to use that. Is that maybe why my sub won't work?
I tried messing with the RCA's but still get a pop on all speakers.
Also tried running some new grounds to the HU but still same problem.
