New girl with a SHO
BoatSHO
SE Michigan
We do not use SCT software. We actually engineered our own tuning software and hardware. The reason for that is we did not want to have to ask a second party for permission to access a table or wait for them to support a platform. If there is a table or part of the logic (within reason) that we want to access we do it! We support and have access to more in the late model, especially Ford, than ANYONE out there!
I don't know how to tell you this...but we're kind of a big deal. LOL!
Okay very cool!! So does your tuner have the display that you can setup on the dash with an lcd screen and it shows gauges? Or is it a handheld that once you reflash you stick it in the trunk and forget about it (like my SCT)? Can it connect via android?
PokerMunkee
I ♥ AWD
Denver, CO
Just saw BoatSHO's avatar.....no wonder this thread is 3 pages! lol
If you go LME route, you'd need a 3rd party app like Torque to display the gauges. Most guys with Unleashed/SCT go this route anyways, as it's way more customizable than the SCT.
BoatSHO
SE Michigan
Okay Okay, I will get a picture with my SHO and make it my avatar... maybe this weekend! :p Thanks for the info on the Torque app, I will look into that. I have a handheld for my Mustang...(SCT) which goes in the trunk for storage. I never knew I could use an app with SCT. I learn something everyday! :hi5:
The Torque Pro app ($5) runs on Android devices and is independent of the tuning device you use. All it does is query the PCM via the OBD-II port using a Bluetooth or Wifi adapter to communicate. No 3rd party app we know of pulls anything from either SCT or Livernois tuners. They are both proprietary devices.
yeah, when they updated the forum it got changed from "PM" to "conversation" but we still call it "pm" And, fwiw, I recommend that you change your user settings to keep your conversations private, otherwise everyone can read them just like a post.
Can't you still get the SCT program that allows you to datalog with the SCT devices? As far as I know that is still available and free to use with SCT tuners. I have the ProRacer s/w so I can do all that, but it is like $300 plus the tuner.
Correct. LiveLink (freely downloadable SCT software) will log from the SCT device. You will need a Windows device to go with, does not work on Apple/Android. The graphing capabilities are negligible on the X4; the Livewire & TSX are better, but still restrictive in scope.
Where LiveLink excels is having the high refresh rates of the attached SCT device. Torque Pro is limited to 0.1 sec refreshes, SCT can log at 0.01 sec (or better) intervals.
I believe the MyCal can datalog, no idea how the owner would do it. Jaimie can better answer on that subject.
If using very fast refreshes, use the minimum number of parameters necessary, no more than 30 or so, to keep the load down on the PCM and the OBD port.
So since Angela has an SCT device for her Mustang, she can datalog with the LiveLink s/w at no charge, so long as she has a Windows computer (which all the smart people have...) ;)
Ha. I assumed she has an Android device already, based on past comments, hence my gentle push towards Torque Pro! Now for actual diagnostics, SCT users should use LiveLink.
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
It is a flashing tool. We do not provide gauges and all that simply because you cannot adjust any of the inaccurate information. Let's take the all too often spoken of Air Fuel Ratio. This is something that everyone wants to look at while driving, mind you...you should be driving...but that is neither here nor there.
FOR EXAMPLE:
Anyone taking the native values and recalculating them into something else that gives a chance for things to be miscalculated. This is the biggest issues we see with data logging or tune monitoring. If someone looks at AFR on a monitoring device, that value is already calculated. But the issue is what conversion are they using? 14.64? 14.08? something else? Now, what about what is in your tank. If they are assuming e10, and you have something more like e6, that instantly makes the applied conversion incorrect. Then, what if they aren't grabbing the right data point from the ECM to log it? What if they are grabbing one with an offset already added in? or a delay? or a commanded VS actual average?
You can see where one simple item like "AFR" is all of a sudden riddled with chances of incorrect data being displayed and/or gathered. Now, we haven't even started talking about boost, or any other myriad of items that could be logged. You see, the Data points that almost all dataloggers use are SAE. Now, SAE standards are nice, BUT they are not designed for someone to do calibration from. They are for repair shops to help diagnose issues with vehicles. So, the level of precision, and refresh rate is not what's needed to do proper calibration development. If you are using a data point with a 200ms refresh rate, but the actual value in the ECM refreshes every 8ms, then the ECM is updating 50x more frequently then what you are watching. Again, you start to see where the issues happen and it's easier to understand why we do not treat the EcoBoost like any other engine before it. Can someone get lucky and eventually end up with a tune that works by looking at the wrong data? Absolutely. Can they repeat those results over and over again without starting from scratch each time? Usually not. And it all stems from having the right knowledge, and data in the first place.
To make it a little easier to picture for most people. If Ford, GM, Chrysler, or any auto manufacturer could spend $30-50 on hardware to datalog and do calibration, why don't they? The answer is simple, you can't, it takes 10's of Thousands of dollars to have the right hardware just for the process to begin. Sorry for the super long and drawn out explanation, but I know that you are new to the community. So I wanted to make sure that I went the extra mile to explain it thoroughly.
8x50 = 400 BTW :) But some good points made. You should understand what you are watching, so always educate yourself, ask questions, etc. Different engine setups are managed differently, so even basic details (or the interpretation thereof) can differ greatly.
Also learn to use the tools (software or tuner device based) to pull codes as needed.
BoatSHO
SE Michigan
Oh my gosh. This is all way above my head :p I have never used the apps or screens on my Mustang, so I wouldn't say it's really needed by any stretch. I really don't need the datalog or anything, I've just seen videos or friends (an ex-boyfriend with his Jeep Wrangler) that had the LCD screen with gauges. I guess it does come in handy that it can ready check-engine codes, again though, never needed that on my Mustang either.
This is all tons of info.
So let me ask this regarding the LME package. I am pretty much thinking 3bar Map, plugs, 160 thermostat and the tune. Is the air intake going to net me anything? Not interested in a better "engine sound" but more performance. With one, can you tell a difference with above mentioned parts?
I love this site!!
SHOForumSponsor
Sponsoring Vendor
I love this site!!
Our MyCal device can read and clear codes if any should arise. Simply plug it in, and it automatically checks for any DTC's. From there you can either view them (if you have a Check Engine Light (CEL)), or you can clear them to proceed to tune your car.
The new cold air will add about ~15 in that setup. The bonus to purchasing like that is that we offer a tuner package with:
Tuner
CAI
Tstat
Plugs
and 3 BAR
Could it be any easier, maybe...but I can't pay for your parts LOL.
RAYJAY
WHO ME ?
UNION DALE PA
Buying used, is there anything simple to look for (on or in the car) to know if I have the Performance Package? I didn't get the original window sticker...although it was a Certified Pre-Owned at a Ford Dealership. I am inclined to think it is not a PP... but not sure why I think that. :rolleyes:
on this forum on the right hand side is a Window Sticker Generator just put in your vin
http://www.ecoboostperformanceforum.com/index.php
