Neon STB
SHO Continental
Moderator
Northridge, Cali
ok ok.. don't get on me about the repost... I did a search..
I HAVE this front neon STB for 95-99 neons.. and it's supposed to go in the rear of gen1/2 SHOs.. but.. I'm looking at the thing and I can't figure out how to get it in? I thought it just bolts right in? Can anyone give me some help? What's the trick? do I have to redrill?
strings1732
RMTE-TRBO-SHO
colorado
the bar has to be turned upside down. Use the picture below to help with putting the brackets on. Once you have both the brackets on, with the bar connected to one bracket, adjust BOTH sides of the bar to the length it needs to be and put it in place, the brackets will need to bend a slight amount but putting the bar up will take care of it for you. Once you have both ends of the bar into the bracket, and both bolts are holding it, tighten them down as tight as you can get it, with the allen wrench. In the directions under the picture, I said tighten down the brackets first, ignore that. Tighten down the brackets after you have gotten the bar in place, with the bolts holding it. Then tighten down the bar end bolts. If I had a picture of mine in the car, I'd show you but this is the best I can get. There is no need to redrill the holes if you install it the way that I described.
Tbne95 au12
greenbeanmtx
King Skidmark
Waco Tx
SHObill said:
Yea & will it fit around a factory sub-box with that offset?
I didnt have my box in on my 93 but i dont think it will clear.
Just for the record though if a gen1 owner wants to do this it works but you have to cut half of the ring on the end off for it to clear because gen1's have a **** type bulge back there on the strut towers. I just cut close to the holes you use to mount it and that made it look like C's on the sides. Worked beautifully.
sho_bc
Dragonboater
Vancouver, Canada
I'm about to do this myself... just to be clear do you think you could quickly show this in a MS Painted photo of the bar?
sho_bc
Dragonboater
Vancouver, Canada
SolidState said:
sorry to dig this up, but wouldn't it be ideal to unload the rear suspension when installing the RSTB?
according to some of the people i talked to last night, its supposed to be loaded?
anyway, back to that photo posted above, do you use only the two inner bolts, and not the rear/outside one? and have the one marked with the red "x" sitting free between the strut towers?? or....? does anyone have any pics of it posted on their rear strut towers?
thanks
SHO92
Upper Freehold, NJ
I can't find my bookmark right now, but I have a BMW suspension tech article somewhere that talks about installing STBs. There is no need to pretension before installing, or either lengthening/shortening the bar after it is installed. The reason is that the point of the bar is to tie the shock towers together. The shock towers will be under tension sometimes, or compression sometimes, depending on the movement of the car. Therefore pretensioning the suspension/stbs will only account for 50% of the suspension movement. There is no way to both tension and compress the bars to account for 100% of suspension movement.
I hope I explained that correctly, but that is the jist of the article from what I remember. Others may be able to explain it better.
Edit: Here is the link that talks about the strut bar. http://e30m3performance.com/myths/Strutbar_Theory/strut_bar_theory.htm This talks about how the bar works, I must have read about actually installing the bar on the BMW forum that I got the link from originally.
HoustinoJillian
name's JUSTIN
usa
disclaimer: this post is purely for my understanding
it would make sense in my head to install the bar when the suspension is loaded (ie car sitting on the ground) because isn't this the position that you want the car to replicate when cornering (flat)? unloading the suspension would flex the body into a slightly unnatural state. when installing something with tension it owuld always tent to return to the state with least energy (if stretched it owuld want to compress, and vice versa). wouldnt installing with the suspension unloaded tend to make the brace favor a flexed position that unloads itself and therefore favor unloaded suspension? sorry if this doesnt make sense, just trying to make heads and tails of it myself
SHO92
Upper Freehold, NJ
It does make sense, but the fact is that the car operates in all different states. Therefore setting the bar up when the suspension is loaded doesn't help when the suspension is unloaded during driving(like cresting a hill). The same applies in the reverse.
The point of the article that I had was though although you can take the time to load the suspension first, it doesn't really matter.
somedude_001
Western NY
well if you think about by pretentioning the bar/towers your modifying your alignment algles which is what your trying to preserve by using a STB in the first place.
somedude_001
Western NY
no i'm not saying to get youre car line up after a install that is not necessary at all. all most people need to know is do not pretention and STB make your car handle better.
greenbeanmtx
King Skidmark
Waco Tx
Hey man im sooo sorry i never saw your post. Sorry it took so long to catch your question. I took the same pic above and airbrushed in pink what you cut off. If you need to ask me anything let me know. Ill be sure to check this thread again. This is what i had to do to get it to fit in my 89, however this alteration wasnt required on my 93.
D0f06d72
greenbeanmtx
King Skidmark
Waco Tx
sho_bc said:
awesome, thanks for the reply. what'd you use to cut it off?
A little hand held grinder with a cut off blade from the local hardware store. Im sure a jigsaw with a metal cutting blade or a hack saw if youve got enough patience would be sufficient. It took all of about a minute to cut it with the cut off wheel.
greenbeanmtx
King Skidmark
Waco Tx
DDakRT said:
Awesome illustration! :naughty:
Thank ya, i tried putting buck teeth on the smiley but it got cut off in the pic. I thought the airbrush pink was a classy touch :p
