NEED to fill MTX trans! From somewhere other than fill hole!!!
techi14
Rockford, Ill
Hi, the fill bolt thing is not coming out. Can someone please tell me if there is a different way to fill up the trans???!!!! From the speedo? The 13mm bolt that holds the reverse idler gear shaft???
thanks in advance
kevinspann
Don't take my advice.
Richmond VA
If it happens again, filling it through the reverse sensor hole is your only other option, I believe.
