need help
sho711
ontario
i have a '93 MTX (white), rebuild tranny, twice, the first one blew because the mechanic didn't know what he was doing, he left out the speedo cable along with the sensor, told me it was the cluster that was busted (he also took me for a 8000 dollar run with sub-standard parts which i had to replace myself after the fact, he went out of business 2 weeks later, and this was an AAMCO transmissions shop) i'm looking to do some serious mods to the motor, tranny, suspension etc.... current mods on the car are stb's (front and back), H-brace, eibach springs, kyb shocks, aluminium sub-frame bushings, sub-frame connectors (still to be welded on), cold air intake, and small things like moog ball-joints, endlinks, new bushings etc... question is what to do next. any suggestions
zblackbeast
SHOtarded
Omaha, NE
first, i would post in the gen 1/2 performance section..
next, i would look at replaceing those KYB's, full exhaust, BBB's honed intake, larger maf, LPM or tweecer.. theres a lot left you can do! :) If youve got the coin, id get a wavetrack or something similar to keep your tranny together!
Huntervf
Bored now
Back in Michigan ... again.
Posts only count in the maintenance sections. This was done to discourage "post *******" in open forums.
And remember folks, this forum is only to report problems with using the forum itself :)
