Need help on replacing Oil Pressure Sending Unit
Arc Angel
Arc Angel
PA
Okay SHO Guru's...I've checked all the postings on this Oil Pressure Sending Unit...but, how in the world do you get to it to replace it on an ATX? I've had it up on the lift while putting on a nice Borla SS Cat-back entire exhaust and mufflers, and, there just doesn't seem to be any way to physically get to the darn thing. And I finally figured out that's what's been leaking for the past year, plus. Looking down from the back of the engine doesn't seem to be any easier. Has anyone replaced one on an ATX, and if so, how about some help. Thanks.
Frank:thankyou:
AREA 91
PA SHO SHOP
Area 91
I'm pretty sure the last one I did was from the bottom. I removed the Y pipe as well.
P.S. Are you enjoying all this rain here in PA??? We're gonna need some Aqua Treads soon.;)
gimpysho
SNJ
oil sending unit
Area 91 has it corectly. fFrom the bottom you'll need at least one flex extension. Perhaps two. It can be done. the leakage is usually coming from the brass spade on the sender.
Good luck,
Gimpy
