Need help! Clutch Fork Problems
darylP
Burbank,Wa
That is why I was wondering about missing the lower plastic pin. Without it the bearing can move around some. If I can not replace them. What would keep the bearing from turning on the Quill?
93rev2sev
Hockeytown
If it was the fork, I would think that ring would be all the way around the PP, not just where the broken finger are.
93rev2sev
Hockeytown
Either pp was slightly defective (tolerances off enough to cause tob contact)
Or...
TOB rocking too much...exposing the tolerances by allowing theedge of the case to contact the fingers.
darylP
Burbank,Wa
One of the two went bad. I guess I'll put it back together with the new parts and see how long this one lasts. Just not sure if I should replace the shaft bushings while the trans is out. Or just install clutch and run it.
93rev2sev
Hockeytown
Oh... I get it...
That's 2 stages of failure. The TOB locked up, wearing through the tips and then later, the TOB case begins cut the fingers off even further down.
sho'noffmtx
Many SHO's
Delano,MN
So is there any source for the plastic pins?
Yes, i bought one from a local ford dealer about a year ago. I believe it cost around $2.00 or $3.00. They had several in stock at the time. :sun:
I think i might even have the ford part number around still. ill go look
darylP
Burbank,Wa
Would it be something like N801-408-S
SHObill
'The Collector'
Rochester MI-48307Detroit
Oh... I get it...
Yea! I see the '2 stages' of failure.
when you re install the new PP-make sure you use the 3 pins in the flywheel & they are not too long to hold the PP off the FW! Do a check fit with the PP to the FW with no disk in there!
-oh & our FW had NO PINS also!!
boat
Likes blue ones
Tallahassee, FL
I would. You have the trans out, good time to do replace those bushings. Takes a fair amount of work and time to take the trans out again just to replace those shaft bushings. It made a heck of difference in combination with the ceramic TOB. You can get the teflon impregnated alumina ceramic coated aluminum TOB release shaft bushings at SHO NUT. They cost around $30. :thumb: good luck!
darylP
Burbank,Wa
I found a site that has the fork pins for 83 cents. But shipping would be $12.34..LOL
darylP
Burbank,Wa
I didnt have the 1st dash but yes that looks correct
Ok thanks. One last question. Is there just the one pin at the top fork? I looked at the bottom and can not see what looks like a hole or anything that looks like it's been broken off.
SHObill
'The Collector'
A small tie-rap or any plastic push pin will work just fine! its only purpose is to hold the TObearing to the fork while installing the trans. after that it serves no purpose! & you are also supposed to jam a spacer between the clutch lever & tranny case to hold it in place just for install. I found a cotter pin on the one we did last night!
itwonder
VA
Time to install a ceramic TOB from shonutperformance. IIRC, the one I purchased included the little plastic pin.
zak
east of Hartford
SHOnut includes the a new pin if you buy any clutch parts from them.
AREA 91
PA SHO SHOP
Area 91
I was waiting for someont to post this.
It must be an old wise tale that the little plastic pin is responsible for retaining the TOB to the fork.
The little plastic pin is for installation only!
