need eletrical help
2tochoose
Delafield,WI
I've started to have an intermittent problem with my car sometimes when I start it the climate control, turn signals, reverse lights, and rear defrost dont work. I know they are all on the same fuse but the fuse isn't blown. Does anyone have any ideas of where to look to fix this? by the way this is on my 89 and it started shortly after the clutch was replaced if that helps.
BlackOnBlackATX
Dutchess County, NY
this may be a dumb question on my part, but have you *changed* the fuse to a different one? tried a dab of dielectric grease on the ends maybe? im kinda stumped as to your problem. hopefully someone else will have an answer.
