My Sho Is Stalling...Help!
Best Sho
Hudson Falls, NY
Hello Again,
My sho is stalling, it started a few weeks ago did once. Now it 2, 3 times a day.
Usually when I slowing down, taking off fast.
When it does stall I just put it in neutral and start it back up no problem.
I ran the codes...
1St time;
KOEOFF
124 (4) related to fuel control. Autozone $20 to $26
157 (R, M) related to MAF. Autozone $76 w/ $60 core charge
332 (R,M) related to EGR , EVR or PFE clean first
KOEON
633 (O) have no idea
CYLINDER TEST got all 9's
2 days later cleared all codes by unhooking battery 10 - 25 minutes ran down to store and back. And got the following.....
KOEOFF
KOEON
116 (R) did not recieve goose test...what ever that means
538 (O,R) engine coolant (ECT) sensor out of range.
Also did the idle reset procedure Scott described
CPS, waterpump, crank & cam seals were all done about 6 months ago, radiator 4 months. Rest was just shocks, brakes and tires.
Any one with any idea as to why it stalling let me know...please!!
Thanks Mike
40BelowSummer
Puerto Rico
The goose test is part of running the codes when youre supposed to turn steering wheel 1/2 turn both ways, "goose" the throttle (about 4K RPMs) and tap brake pedal, and also on an ATX turn OD off&on once.
Was the car properly warmed up before checking codes the second time? If it wasnt fully warmed up this could cause the ECT sensor out of range code.
Since you got a code 332 both times try cleaning your EGR valve, instructions here.
