My SHO cranks over, but only starts sometimes
Andrew Kishman
Chaparral,NM
Recently my 93 SHO wouldn't start, but it cranked over fine. Then after i got it towed back home, it started up fine. Half the time it will start right up, but after I let it run for a little while I shut it off and then it wont start back up. I am not sure what is wrong. :confused:
SHOclub1
Washington, IL USA
Andrew,
You might want to try some of the tech sections of the Forum, but I will give it a shot.
First check that the wire connection on the back of your coil pack is tight. This can work loose and cause the car to not run or start.
Then if that doesn't help, you might suspect the crank sensor. If that gets hot it can cause a non-running situation, but usually that happens on the road, not as you start after the car is hot.
Be sure to post on some of the tech sections to get other ideas.
crystizel
