f150fan
nik97 said:Atop your'e trans is a white harness connector. The purple wire with a yellow trace is the circuit for the TCC. Basically cut and splice in an on/off switch in series with that wire. When the circuit is complete, the PCM will control the TCC on it's own accord. When open, the PCM has no controll of it at all and it will not apply. The PCM will also take a moment to respond when the switch is closed anfter being open. The PCM has a diagnostic monitor for this curcuit like many others so it will trip a code and your'e MIL will illuminate occasionally and then go out. This is not really needed unless the TCC scheduling has been altered by a reflash.
---Nice car. What A-pillar pod are you using and where can I find one???
I don't have a reflash on my car....but I do have the annoying T/C lock and unlock sequence with the climate control on. I'm pretty much looking for a cheap way to disable the TC and this looks like it should work I'm thinking?!?
Thanks for the compliments....The pod guage is made by autometer meant for the 94-95 Mustang Hardtop. Some minor sanding and it fits great!
