93rev2sev
Well, It's on!
Last night, I picked up a hoist (borrowed) and I should have the 3.2 out by tomorrow night.
This thread will chronicle a budget minded 3.2 swap.
With the help and encouragement of the SHOForum Community, I will be pulling a 1995 3.2 (115k on the clock) from a rear ended parts car and installing it into my 1993 Black MTX this winter.
Here's the kicker:
The 93 is my daily driver and I am aiming for only one day of downtime.
Step one, once the motor is pulled will be inspection/cleaning. I anticipate needing to replace the following on the 3.2:
Swap related:
Timing cover (middle and lower)
Rear Timing cover
Water pump housing
Accessory belt tensioner
Accessory Belt Idler.
Oil Pan
Oil Pump
Power Steering Bracket
Lower timing cover
Timing tensioner
Crank Pully
A/C Bracket
Alternator and bracket
Rear Exhaust Manifold
Wear related:
Plugs
Wires
Rod bearings (I might take a look at replacing the mains also if the rod bearings looked wiped)
Water pump
Crank Sensor
Timing belt
Valve Shims (where needed)
Intake and valve cover gaskets
Cam seals
Cam Chain Tensioners
Anticipated Swap MODS needed:
Grind mounting boss on front head to allow for 3.0 accessories.
Plug EGR port on intake.
Help me fill this out....what else do I need to MOD?
Here's the kicker:
Swap related:
Rear Timing cover
Water pump housing
Oil Pan
Oil Pump
Lower timing cover
Timing tensioner
Crank Pully
A/C Bracket
Wear related:
Plugs
Wires
Water pump
Crank Sensor
Timing belt
Cam seals
