ponchodan
Originally posted by ponchodan:
Thanks to everyone for all of your help, I really didn't expect these kinds of helpful responses! I've ordered a cam sensor and will install it on either Monday or Tuesday. Hopefully it will solve most of my problems with the car. Now if only I could figure out what those peculiar popping/rubbing noises are from both sides of the front of the car when I turn the steering wheel at low-speeds! I didn't even know this site existed when I bought my SHO, but I sure am glad I found it! Thanks again.
BTW Doggee, you have mail.
Wow, this really stinks. I put the cam sensor in today and it didn't help anything. I pulled the codes after having the car run for a little after the install and I got these codes:
Was by myself, so I only ran a KOEO test again today.
Hard:
543 (again)- secondary fuel pump circuit failure
Not hard:
211- Profile igniton pickup (PIP) circuit fault
214- Cylinder Identification circuit failure
543 - secondary fuel pump circuit failure
I did clear all previous codes from before the install, so I don't know what that 214 is all about. When the car was cold and I had the clutch in, the rpms kinda bounced up and down between 1300-2000. After driving for a mile or so, the problems began again with the bucking and surging. Then the car died while I had the clutch in coasting down a hill, I started it back up while rolling and limped it back (in shame
