My new low budge CAI snorkel for my Supercharger.
jeanrw2000
Lechon Asado!
Brawley, CA
hey guys i got a little bored yesterday i went to home depot and i got me some PVC fittings and BAMN!
here it is:
i acctually didnt have to used that huges looking Coupling so i went back today and got my money back on it.
about 5.00 bucks!:biggrin:
and here for the final product and for less than 15.00 dollars before tax:rofl: :nut: , yes i know i need a bigger filter i am working on that rigth now.:dribble:
sorry if the pick are to big, i know is kind of cheese but hey for $15.00 i loved it....
mosho93
Well-Known Member
Wausau, WI
Looks damn good to me! :thumb:
i have a setup something like that in the garage except...umm..mines not for a Boosted SHO :)
jeanrw2000
Lechon Asado!
Brawley, CA
thanks boss, the good part is that it works very good to my surprise and it did i mentioned that it was very cheap??:evilgrin: and since it goes inside the fenders well is not very visible. :naughty:
mosho93
Well-Known Member
Wausau, WI
Yep!! me and my buddies built one for our sho's just for track days to try it, but for some reason, we seem to forget it the couple times we have gone??:nut:
jeanrw2000
Lechon Asado!
Brawley, CA
lol now something!:nut: funny though:dribble: :thumb:
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
We came up with the ultimate CAI. The intake pipe is abour 6" long and goes straight through the inner fender (outside the engine compartment where it is cool). No friction losses from the bends in the pipe. I found a super large (and flat) Airaid filter that fits perfect and has about 3 times the area of the SHOshop filter. WHen you are at the track you can remove the corner marker and it is a straight shot into the filter. If I ever get spare time, I plan to build a small ram air scoop. When to corner marker is installed, there is still lots of room to get free fresh air from the front of the car.
I thought about going the route you did with the plastic pipe, but the friction loss from the bends, and the larger fender hole convinced me otherwise. I can punch the hole through the inner fender without cutting into or weakening the box tube support.
If you are interested in more info, let me know.
- Mike
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I will get some pictures and a part number for the air filter.
I spent two or three months staring at and cutting up a scrap car to find our "simple" solution. Basically, you come as close to straight as you can from the intake of the supercharger. Since there is the reinforced box tube in the fender (and I did not want to cut into it), I put the hole right below the box tube (about 1/2" lower than the intake of the supercharger. I used about a 5-6" long piece of 4" exhaust pipe for the intake. I took me about three tries to get the correct length. You want about 1/2" gap between the pipe and the supercharger, and you want it to stick through the inner fender about 3/4" so the air filter can mount. The pipe should be cut with a slight bevel on it to account for the angle, and then I did a little hammering to make the beveled cut round (I used a trailer hitch ball as an anvil).
The trickiest part is installation. Slide the 4" silicone coupler all the way on the pipe. Feed the pipe through the hole in the inner fender and directly into the air filter (since the air filter is also a tight fit). Then once the pipe is in the air filter, you can slide the silicone coupler back up the pipe and onto the supercharger intake.
Like I said, I will get some pictures, but the design is as simple as it gets, just the execution of the design is tricky.
- Mike
LeddZepp8687
The Keg Rider
Naperville, IL
You should see the cold air kit I made out of PVC a while back...Now that was nice!
I have an industrial grade heat gun that plubers use to heat and bend PVC. Boy did that look good, no extra PVC couplers needed, just tubing and some silicone adapters.
jeanrw2000
Lechon Asado!
Brawley, CA
- Mike
yeahh man sounds interesting put some pictures!:dribble:
jeanrw2000
Lechon Asado!
Brawley, CA
what happen to it?:oogle:
For going though the fender opening without doing any cutting there are 4" rubber plumbing 90s. These will deform to fit the opening but not reduce total area. And a 4" opening filter connects right to the end of them.
1993MTXSHO
Its a Taurus...
Jersey
wow that looks pretty nice, I think i would do that if i didnt have the sho sho 80mm cai
jeanrw2000
Lechon Asado!
Brawley, CA
SeanMc said:
didn't the Jackson 5 sing that? "It's ABS, not to be confused with PVC"
for what its intended used is, it doesn't make a different if is black or white!:rofl: :naughty: :biggrin:
313tiger
