My engine's missing
jdh00
Westbrook, Maine
I just replaced the t-stat and while I was right there I cleaned up the coil pack, the connections, and the wire ends. I put it all back together and now it doesn't run right. I get some backfiring and it just runs rough... I assume my wiring order is correct on the coil pack. I've got them plugged in as follows: from front to back on the right side of the pack, 1,2,3.. then from back to front on the left side 6,5,4. When I say back and front i'm talking about the relation to the car. I also rinsed a spot, underneath the throttle body with some water, after some coolant leaked down there, is there a sensor or something that could cause misfiring if it got wet? Help
92MTX, Dynomax exhaust, Coneless, Conical filter, 17x9" Cobra R's, 235/45/17 Dunlops/Pirellis
It sounds like you reconnected the wires out of sequence. Check the correct sequence below. If that doesn't restore it to normal, be aware that any water around the secondary ignition system (coil pack, wires and plugs) is a possible low resistance path to ground. Could you have gotten any water in the plug wells? How old are the plug wires on the engine? Broken down insulation can certainly show up around moisture.
Firewall
5-1
6-2
4-3
Radiator
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
[This message has been edited by sdpatt (edited 11-24-2001).]
jdh00
Westbrook, Maine
Once again... Your knowledge is greatly appreciated! I had the wires connected in the wrong order
I learned something though
Thanks Scott
DfwSho
Arlington, TX USA
Thanks Scott
What is that? I'm assuming it is to avoid 'rinsing' your engine?
Goofball.
Laurence
Dfwsho
SOLD! 11-3-01 94 mtx, 17x7 SVT Thunderbird, 225/50/17 Michelin Pilot XGT-Z4's, Eibachs/Tokicos, '96 brake upgrade, Perf. Plus y-pipe, UDP's, dynomax, K&N, PIAA 1500XT, Gen3 badge, TX plate "MTX SHO", Alpine CD, "Yamaha" badges
Gtech Pro 0-60mph 6.36, 1/4-mile [email protected]
98 Suzuki GSXR600
DFW SHO's homepage
