My 94 mtx sho wont start help
shomoman
My 94 Sho 3.0 ran fine when parked and sat for two years I recently changed valve cover gasket cleaned my butter flies fresh spark plugs and spark plug wires and new fuel filter with fresh fuel and royal purple oil change before trying to start it now it will not start it just sounds like its trying to when I spray starter fluid in it it starts to start up like I'm not getting fuel but it has fuel pressure to the top end please help
sperold
Last to Know
It should start and run if you are using starter fluid, at least until the fluid is used up.
Check some plugs to see if they are wet. If wet, it is an electrical issue, if dry it is fuel issue.
Also, sometimes injectors need a cleaning after a long time of no use, or the impulse wiring could be faulty.
See if you have any codes, active or stored.
good chance the injectors are gummed up and stuck, if it sat for 2 years or so.
itwonder
VA
Use a spark tester to make sure you're getting a strong spark, and double check that you have the wires on the coil correctly; the pattern is counter intuitive and very easy to get wrong; it has been said that some repair manuals have it wrong.
bmytych
