My 91 will not start
shadownos4
For The SHO
Wisconsin
A while back my 91 stalled on me as I was backing out of my driveway and would not restart. Well I have switched out the cam sensor I have also removed the crank sensor, I have replaced the coil pack I have also tried three different dis modules can anyone give me any ideas I am about done with these cars. If I can't get it to run it is going on the for sale fourum.
shadownos4
For The SHO
Wisconsin
Yes I replaced the crank sensor. There are all new sensors coil and i have tried three dis modules
shadownos4
For The SHO
Wisconsin
Sorry ment to say replaced Crank sensor. I am so upset with SHO's I can't even think.
93rev2sev
Hockeytown
Check the fusible link coming off of the battery. It powers the CCRM and computer. It's a 14Ga wire that necks down to an 18 or 20 ga fusible link. This link is located almost directly under the radiator filler neck.
Have you been able to pull codes?
kevinspann
Don't take my advice.
Richmond VA
Or hooked up a compression tester?
Timing could have jumped enough to make it not run/start.
shadownos4
For The SHO
Wisconsin
I had to charge the battery and try to start it again and this time is stored code 21 and 24. Having to do with the coolent temp sensor out of range and air intake sensor out of range. The link off the battery how do you know if it is blown? I unpluged it but there is no sign that it is blown. I am going to check for spark tonight afterwork.
