mtx replacement
frosho
WOLFMAN
Tyngsboro, MA
what does it take to remove and replace an mtx tranny on the sho? does the engine have to be pulled to get it out or can it be removed from underneath?
Ishodu
You need to support the engine with a engine brace, (try a search and learn how to make one) then you must remove the subframe and things attached to it like the rack, motor mounts, ect. A search may show you all.
Rockledge
Pluggin' away
Connecticut
It is well worth picking up the clutch installation video from SHONUT. It walks you through thew whole process, from start to finish, desribes the tools you will need, even shows you how to make an engine brace.
frosho
WOLFMAN
Tyngsboro, MA
thank you i will consider that... i'm still weighing all my options right now so we'll see...
