MTX passenger side Link Shaft bearing replacement
NSR818
California
Anybody know where I can get a replacement bearing for the link shaft? It's loose and it makes a chattering noise at low speed take off.
"The sound is like shaking a plastic bottle full of aspirin."
I am also willing to purchase a used one under good condition.
There is no grabbing issue just that rattling noise when i take off normally on first gear and second. I noticed this bearing was bad when I replaced the passenger side half-shaft. I inspected the bearing and it wasn't intack anymore. The only thing that's keeping it together is the pressure between the bracket and the CV axle.
Thanks..
Noli R.
Ganday B
Norton, MA
I had that problem a few years ago. Ford does not support the bearing anymore and no one had any on the shelf. THANKS FORD! You will have to find a used one.
Good Luck.
