Mtx Noises And Bogging
bcf4696
Merrimack, NH
My 95 MTX w/68,000 miles has a few odd isssues. I just replaced the cam sensor, v/c gaskets, plug wires (A/C Delco fit great), and clutch was replaced 10k ago. When letting the clutch out hard in reverse mostly, there is a single pop noise from the left front of the car, sounds like something big is moving. Also, when cold, the engine is bogging under moderate acceleration under 4k with no check engine light. Ok, the last thing is the transmission. When sitting at idle stopped, if I let the clutch out, it's really tough to go back into first gear. If I get it into first go, usually by going into third first, and don't release the clutch it will go in and out no problem. As soon as I let the clutch out again, same thing, hard to get back into first. Any possible suggestions?
e_clouser
04DrpTopGT
Near Harrisburg, PA
as for the noise, I would say check motor mounts and SFB's. The tranny issue, is it easy to shift when car is not running? If so you have a clutch issue, if still hard to shift, tranny issue. Good luck.
