mtx iv differences??????????
ashodude
florida
will a 90 transmission work on a 92? is there a difference on the trans between cable and rod shift?
sperold
Last to Know
The transmissions will interchange.
The shifters will interchange.
Your exhaust system already has the jog in it to use the rod shifter (if it is a 92).
ashodude
florida
thanks for the info. im in tampa. the car pops out of 5th gear when driving and i cant always find reverse.....could this be a linkage issue?
KyngofPop
Freday-day
Charlotte NC
Soundst o me like a problem with the synchros. When's the last time you changed the tranny fluid and what type did you use?
ycode90
Out in front!
Change fluid first see if that helps . The rod shifter is a better design . But not really worth it if the cable unit is okay . My cable shifter felt firmer and tighter to the point I was a little disappointed in the change .
ashodude
florida
last fluid change was a few years ago with dextron 3, when we did 5th gear syncro....(there were only like 3 left in the USA!) also the blocking rings and the shaft the syncro sits on......im hoping its a fluid or linkage issue....
itwonder
VA
Switch it to Mobil 1 Synthetic ATF. See if it gets better in about 50 miles of driving.
ashodude
florida
so the fluid was full....but also grey and smelly.... some chunks of metal as well....not a good sign. also the linkage is very sloppy. going to fix the linkage and go from there. i thought i seen on here someone selling bushing kits...anyone know who or where these are?
DJSHO91
Durham, NC
SHOsource.com offers the rod shifter(and cable shifter) bushing repair kit. her is a link to the parts page.
I replaced my MTX's fluid with Royal Purple Syn. ATX fluid and have been very impressed. It has really improved the notchy syncro feel I had experienced before the change. I would highly recommend the Royal Purple product. :salute:
