Mtx Help
bwhite20
georgia
i have a 93 sho and my transmission come to find out was fried i have an option for a pre rod shifter transmission for 100$ how can i make it work
Racer X
SHO Pilot, Retired
Connecticut
Make sure it's good, internals spin without binding or noises, etc...
Then remove all the cable shift parts from the transmission and install. The rod shifter will bolt up to the case, there's no modification needed.
NORMAN
FL
The cable shift transaxle is the same so you can use it. If the differential pin made a hole in the case, then obviously you need a replacement case half and another differential. Plus whatever else that broke when the pin was thrown.
