Hello! Havnt been to forum in awhile but I had some time today...anywho, I have a 93 MTX that gives me trouble in all forward gears, seems like its not fully locked in unless using force(then an audible clunk is heard) Recently replaced the clutch and TOB (southbend stage 2) along with new clutch cable, shifter bushings, clutch fork bushings, and had flywheel resurfaced. I adjusted clutch cable properly and can tell the release of the clutch is not the issue as there is no reverse grinding and its hard into gear even with the engine off. I thought it was a trans fluid problem so changed and checked fluid levels several times but no improvment. I also checked for abnormal play in shifter linkage but found none... The shifting was easy before clutch replacement even with most of the fingers on old clutch missing! Im wondering what to do/check next as a see no adjustments for linkage??? Could it be synchros in transmission or a linkage problem?? Any help would be great
