Motor Mounts
Fine89
Pottstown, PA
I got a quote from the dealer for $502.00 for 2 motor mounts installed. Does this sound right!!!????
They tell me this is why my car clucks when pulling out and braking.
Thanks
1. $502 sounds VERY high to me.
2. Because it is chicken?
Scott
RJ-92
Crappy NYS
That's way to high. They sell the mounts for $100 a piece. So they're charging you $302 for labor. That's too much. Get a seccond opinion
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
[This message has been edited by RJ-92 (edited 12-07-2001).]
jthomas68
Area 51
That`s way high.You can to the front without even jacking up the car if you needed to.I`m not sure that`s your "clucking"
problem though,mine was torn and didn`t make a "peep"
Jeremy Thomas
Modified 91+
Pic Of The Week:
Fine89
Pottstown, PA
Thanks...I'll get another estimate. The 'cluck' was actually a thump....when I pull out or stop I feel the steering column move. It's got the shiny spot on the intake and more torque steer than ever. Are the mounts something a weekend mechanic can do?
I did the test in the Shotimes FAQ and didn't see the motor rise!?
The 'clucking' must have been a slip of the fingers - I got chicken when I heard the cost!
Blast7
Rochester, NY
If you are going to replace you front and rear motor mounts then you should really get reinforced ones. I bought mine from Performance Plus and I think they were around $220. I had a local mechanic put them on for $100.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
casca
HOTlanta
I think... my car is making that same noise yours is..... when I brake or step on the gas it makes a clunking noise in the front end.. really loud
*Heather*
92' Silver Frost MTX
aim:xxcascax
[email protected]
FordLover
Houston, Tx
Mine makes a knocking noise when I let off the brake at a stop sometimes. I think it's either motor mounts or strut tower bushings. But it's just a noise, so I'm not going to worry about it for right now.
-Martin
AOL IM: FastTaurusSHO and Kyle5324
My girl
92 Silver UDP's, coneless, Alum SFB, SHOnut motor mounts
93 Green MTX, High Rev's Jr, lightened flywheel, grizzly paw TOB, fishtank lights, SHOnut motor mounts, K&N panel, coneless, SHOshop linears, tokicos, alum SFB, 26MM RSB, wigwag headlights, 225/55ZR16 firehawk SZ50's, G-tech [email protected], 0-60 in 6.31
My Webpage
my89sho
NC
my car did the same thing. one day i hit the gas and the whole engine dropped. lots of damage. get it fixed.
sprink268
I have the shiny spot but the engine doesn't rise either. And I have newer reinforced mounts. Might be the hood insulation blanket dragging on the motor. I am going to get a front mount from SHONUT and finally install the trans mount and see if that helps. As for the thump or clunk, I would highly recommend replacing the subframe mounts. Go with the aluminum from SHONUT, also.
thatSHOguy101
