minguns wiring question ( alt pics included)
NovaSS
Project MINIGUN
well its been a while since I pulled the harness and with help of a factory wiring diagram I have mapped most of it out, except one post on top of the alternator
doner car....
1994 SHO mtx
its the post next to the nsa sticker, ( I assume it goes directly to battry positive)
the yellow/white goes to a fuse link, power distribution box then sarter solenoid.
the green/red goes to ignition.
100 1125
over all pic.....
100 1126
krednjen
Kit car/90 SHO Derek SA TX
San Antonio TX
Main charge post. Straight to hot side of battery, or main feed on the starter, may be more convienient. Either way, dosent realy make a difference. You could even have a power distribution block, if that suits you better. Long story short.......just juice man; just juice.
Phoenix
SHOHOLIC
QC , Canada
Dont want to contradict but on mine (94 mtx wirering) that cable goes in the wirering over the rad, back to the fuse box pole , then from there it goes to the starter then from there it goes to the batt.
NovaSS
Project MINIGUN
Your not contradicting, as per the factory thats the proper route and it works. Since Im not using the factory power distribution box Im just going to jump to the starter then to the battery.
NovaSS
Project MINIGUN
i would like to see some more pics of this project
heres a few of major hurdles...
exhaust , minus mufflers.
100 1081
gas tank mocked up..
100 1022
3.0 bored to 3.2
3.2 injectors
shonut +20 cams
over sized stainless valves
3 angle valve job
FPS valve springs
bronze guides
minor bowl cleanup.
BBB
BBB air horns
mild port matching, most other work in primary tubes
aluminum fly wheel
aluminum underdrive pulley, power steerring and A/C delete.
stainless headers
100 0984
tranny after quaife install..
100 0938
11.6 brake upgrade on all 4 corners. custom struts, springs, adjustable camber/ caster plates.
000 0006
