Roller 5.0 blocks are a dime a dozen. I could pull three complete roller 5.0s for $100 apiece at the next Pick-your-part half-price weekend assuming someone else doesn't get there first.
Playing devil's advocate here, but please tell me again why OHC is an advantage, particularly when you're talking about two inline valves and nothing special in terms of port design?
agreed, that the 5.0 rollers are plentiful, but I personally don't know what the block numbers translate to by heart, there's the chance of picking up a motor for 100 that isn't roller. There was alot of fuel injected 5.0's produced with standard non roller cams...ANY Lima 2.3 can be roller cam'd w/stock parts...also, if you want to stroke the 2.3 to a 2.5, the crankshaft is available for that in just about any junkyard thanks to the massive quantity of fleet rangers...by combining parts from multiple years of mustangs/turbocoupes/fairmonts and rangers you could build a pretty hot little motor, all with oem parts...the hottest you can build a 5.0 with junkyard oem is to find a wrecked svt product, or a v8 explorer, and even then it's still doesn't have aluminum heads...knock it all you want, it's a little motor with alot of potential...and besides, even my grandma has a 5.0 in her car...it's as common as the cold...
high revving engine with simplified and reduced quantity of valvetrain parts and travel. reduced number of failure components...less frictional hp loss...
...but we're not talking about a DOHC motor, we're talking about a nice, narrow, lightweight pushrod V8 that's smaller than a 60-degree SHO V6 in just about every dimension except block length.
I haven't tape measured it, but all the gm ls motors I've seen are big, and again heavy...is there a perticular LS motor your thinking of? because the last time I changed plugs on an LS-1 camero it was a major PITA to get the back plugs out, it'd think 30degrees less v woulda helped that significantly. I agree that yes, the plenums on the v8 sho are large, but I'd think at this point with diving into fabbing up an oil pan and adapting to the mt-75, sourcing the necessary parts and building a harness and engine management, a custom plenum would be the least of the worries...
Only because it'll be any stock Sierra XR4x4 transmission or transfer case's worst nightmare.
I agree it's not optimum (without the strength mods), but neither is the vw quattro unit, or the jeep awd viscous coupler unit, it's kinda a given when diving into AWD that it's going to be a PITA, and as I mentioned before, there's the hassle of any future repairs to these AWD components
