digsj7
Digsj7
Ok guys, I'm at a loss? I got gas the other day, drove my car home about a mile..and as soon as I pulled into my alley it died. No warning, just died. First I thought it was my fuel pump because I use to be able to hear it when I turned the key on and after it died I cant hear it anymore. Before I checked for fuel, I checked for spark. I pulled a plug wire and set a screwdriver in and set it on the frame, there was no spark. Then I pulled a plug and left it in the wire...still no spark on the plug.
I tried to perform the KOEO test and I can't get the engine light to start blinking to get some sort of code. I performed the test EXACTLY how your suppose to via shopheonixproject (except getting the car to normal operating temperature because I cant get it to start!). I seriously dought the engine light is burnt out because I've had a O2 sensor code for a while and the light comes on everyday.
How can I figure out what is wrong? I really want to avoid throwing random parts at this because you all know how much that can cost! HELP!!
